Depends on the construction. Since it is 6" shy of the 102" max trailer it will be a little tight. At ~77" the Viper mathematically will fit but...........
To increase your odds of success it should have recessed (or very low) wheel wells so the doors can be opened and an escape door may be necessary. An option would be to have ramps attached to the floor of the trailer to get the car above the wheel wells. It will also aid in securing the vehicle since it is very low. Aluminum units are available but simple 2" X 12"s will do the trick.
For ingress the trailer should have a pronounced beavertail, 77" door w foldout (long entrance ramp). Run the tongue jack up as high a possible to get the ramps at an optimum angle.
Hope this helps...........best, Bret.
