Help with re instal of tranny
Mamba52
Atlanta / Hollywood FL
Ok so I have the new flywheel installed and for some reason the tranny will not go all the way in. It slides in but the last inch it just stops. It feels like it hitting something. Any help would be great!!! Thanks Shawn
bluesrt
get back on the rear of tailshaft with both hands and rock up and down with good force pushing in, another try lastly is(you need to be careful) is instal bolt on each side and gently install bell houseing bolts back and forth,side to side in small increments and it will fall into place
happy56
Mooresville In
Sounds like clutch disc is not exactly centered and the front of tranny is not going into pilot bushing
M
Mamba52
That's what it was. Removed bell housing and clutch. This time I made sure the clutch tool moved in and out smoothly and did a test fit with the bell housing removed. Thanks for all your help!!!!!
Viperless
MN
I had the same issue and I didn't touch my clutch. Just swapped the trans. I struggled trying to get that thing in for a couple hours. I tried everything. Finally took a break cause I was about ready to throw something across the garage. Came back a while later and it popped right in. LOL
tbsviper
Reading this brings back fond memories of wrenching on my cars in my youth....those were the good ole days!
sloth
