I need help AGAIN!
Bad_Byte
Corpus Christi Tx
I'm replacing a fuel pump on a 97 GTS.
How the heck does that vent tube come off?
I don't want to break it so I am reluctant to pry too much. It may have a nut behind it I simply don't know. Does anyone else?
1TONY1
Dalton Ga. (Chatt. Tn.)
you pull it straight off, you may have to twist and turn. just did it last week.
Thats correct.
Leave the nut/ring tight on the module to make it easier. A little heat from a hair dryer might soften it a little but MAKE SURE you have no fumes in the area. Maybe have a fan blowing over the area before hand
Bad_Byte
Bad_Byte
Corpus Christi Tx
Thanks, guys.
That is what I was thinking but I didn't want to force anything and risk cracking the plastic.
Lennatave
