Need some help with KW's, ride height way too high, can't go lower.
redtanrt10
Dana Point CA
Magnus, I didn't notice the stance of you viper in the track video you posted. You may need some stiffer springs and you should definately increase the rear ride height. Your gonna shread your inner fenders, once they go they the top bolt starts to tear into the tires. Here's mine set for the track using rear 18's like you have, we're similar in the front but the rear is very different Mike
M
Magnus_
US
Hey Mike, thanks for all the help.
I've definitely decided to go with stiffer springs through JonB. Haven't picked the exact #'s yet but am in no rush with SEMA/PRI and winter coming up.
I haven't had a chance to check my fenders from wear with the car lowered on the stock-soft KW's. When I do though, I'll post my findings in this thread.
redtanrt10
Dana Point CA
Just trying to help, went throught 2 sets of rears on my 06 and groved the RR tire, if you need them X2 builders sells used ones reasonably (2003-2009 coupes/convertivles are all the same)Check the ride hight too, good rule of thumb 2 1/2 fingers, or more, from the tire to the fender lip.
What is winter??
