No dash or running lights
Robin747474
United States
Hello, got a issue trying to figure out 1996 rt , pulled headlight switch have headlights, no running tail lights, fog lights, or dash panel lights dash panel fuse looks fine switch seems not to be hot, worked fine last time I drove, should I check anything else before I pull the switch out thanks
When you push the brake pedal do you get both tail lights and the 3rd mounted light on?
chris2298
