1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Pinning the crank
Discussion in 'RT/10 and GTS Discussions' started by anaconda666, Jul 6, 2009.
  1. anaconda666
    anaconda666 Enthusiast
    416
    Jan 5, 2008
    Toronto, Canada
    Installing a Paxton on my '98 GTS. Manual says to drill 1 1/4" in to the balancer and crank. I have only been able to get 1" in and then it just stops. I guess I am hitting the crank which is harder steel. I have tried different drills at different speeds -with oil, without oil, pushed so hard that I broke a bit, and still can't get in to 1 1/4". Anyone else have an issue? Thanks, Ron.
  2. GR8_ASP
    GR8_ASP Enthusiast
    5,637
    May 28, 1998
    When I did it I broke several bits as well. i used very good tungsten carbide drills. Not sure what type of drill bits you are using but the crankshaft is hard stuff.
  3. plumcrazy
    plumcrazy Enthusiast
    53
    16,243
    Jun 9, 2003
    ALL OVER
    ditto, same here
  4. anaconda666
    416
    Jan 5, 2008
    Toronto, Canada
    Been using high speed steel bits. Will buy some tungsten carbide bits and keep trying. Thanks!
  5. VENOMIS
    VENOMIS Viper Owner
    123
    Oct 7, 2007
    Riverside, CA
    Use solid carbide. I had a machine shop and carbide would cut just about anything. Be prepared though they are expensive! That carbide would drill out your tungston...
  6. anaconda666
    416
    Jan 5, 2008
    Toronto, Canada
    Did you use oil or dry?
  7. VENOMIS
    VENOMIS Viper Owner
    123
    Oct 7, 2007
    Riverside, CA
    in that application i would use some type of cutting oil...
  8. VENOMIS
    VENOMIS Viper Owner
    123
    Oct 7, 2007
    Riverside, CA
    If you wernt in such a hurry i could probably send you something. I have a chit load of cutters and drills bits from when i closed it. Be careful though carbide is very strong but also very brittle. It will shatter like glass, but thats why it cuts so dang well! So if you break the bit in the crank you would practicaly have to grind it out. SO BE CAREFULL!! You can PM me if you have any other questions. Be glad to help if I can.
  9. snakebitdave
    snakebitdave Enthusiast
    663
    Jan 26, 2003
    Mi, USA
    I just pinned my 96 GTS last week using Roe Racing's kit with provided drill bit guide tool, bolts, pins and drill bit (which seemed to be just a high speed bit). Per their instuctions I drilled the two holes without lube. Using a Makita right angle drill motor I didn't have to raise the engine or move the steering rack.
    No problems encountered.
  10. KingSnake97
    KingSnake97 Enthusiast
    344
    Mar 4, 2001
    CHGO,IL,COOK
    Can you snap a few photos? I just bought a new balancer from dc motorsports. I would like to pin mine while its off the car.
  11. snakebitdave
    663
    Jan 26, 2003
    Mi, USA
    Too late for photos as it's all back together. You can see a picture of the kit on Roe Racing's web site.
  12. BullRider
    BullRider Enthusiast
    45
    117
    Jul 15, 2007
    Naples, FL
    I pinned the crank during my ROE install, and there was no way that I could figure out how to drill them without raising the motor. You must be magic!
  13. Steve 00RT/10
    Steve 00RT/10 Enthusiast
    1,751
    Nov 18, 2000
    Michigan
    [​IMG]
    The crank pulley does not need to be removed to do this. I used a cobalt bit, air drill, and cutting fluid. It drilled like butter with the cobalt bit.
    For me, this was the most time consuming part of the install as I didn't have the right tool to start with. I also found that the 12 o'clock position would not work on our car. I ended up around 11:50 after screwing around with several different positions to try and get the drill in there. I know a guy who did it with a flex drill bit set up. I guess it worked well, but was done after I was finished.
    Steve
  14. crazyspeed
    crazyspeed Enthusiast
    611
    Oct 8, 2006
    Buffalo, NY
  15. Simms
    Simms Enthusiast
    3,320
    Oct 22, 2003
    Pittsburgh, PA
    A right angle drill did the job for me.
    [​IMG]
  16. LPDesRoche
    LPDesRoche Viper Owner
    101
    Jul 2, 2007
    Sunbury, NC
    Did it without raising the engine or removing the steering rack on my buddies 2000 GTS. Used the Roe supplied drill bit in their pinning kit and my Ingersol Rand pneumatic right angle drill. Went in with ease.
    Not sure how you could actually pin the crank without removing the pulley, as there is no way to bolt a jig up there with the pulley still in place. You would just be drilling into the crank face and not half balancer/half crankshaft?
  17. Steve 00RT/10
    1,751
    Nov 18, 2000
    Michigan
    Remove 2 bolts from the crank pulley and bolt the jig in...put the recess out, mark the bit at 2.45” and butt this mark at the recess portion of the tool. This will accomplish the same drilling depth as having the recess in and the pulley off. The recess is the thickness of the crank pulley face.
    Steve
  18. All Blue ACR
    All Blue ACR Enthusiast
    1,054
    Aug 15, 2007
    Rocky View County, Alberta
    Is this something required to resolve a weakness (dumb design)on all cars?
  19. 99 R/T 10
    99 R/T 10 Enthusiast
    10,315
    Jun 4, 2001
    Enterprise, AL USA
    Usually required for all Supercharged applications. I would guess because the engine spins up so fast. I have heard of stock engines losing the balancers too, possibly due to the crank bolt not getting torqued properly to 250 FL lbs.
  20. Martin
    Martin Enthusiast
    1,810
    Dec 15, 1997
    What he said :)
    Superchargers require quite a bit of grunt to run them - and for big engine applications, they need between 80 and 100 HP at high RPMs. Add all the other accessory drives like power steering, air conditioning, water pump, and alternator, and you're now putting somewhere around 150 - 170 HP of load on your crank. It's not uncommon at all for the crank pulley to spin off.
  21. plumcrazy
    53
    16,243
    Jun 9, 2003
    ALL OVER
    get rid of the junk OEM balancer too while you're doing this work, go with the ATI
  22. sircumference
    sircumference Viper Owner
    Mar 4, 2006
    New Zealand
    I have access to a CNC machine shop . All my viper engines have the front damper coming apart . I am looking at makeing a new steel damper for these engines . the more i make the cheaper thay will be is anyone interested , sorry at this time no prices but i thought i would put in the holes for pins and cut a keyway as well for those with the engine apart . . . these will run either the std outer ring which gives no problem and bonded rubber to the new hub .or a new outer ring as well thoughts please . I have a friend who has a business rebulding dampers and these are his suggestions . I am an engine reconditoner here in New zealand . . We can also make a new alloy belt pulley for the crank and offer the lost as one balanced as an assy .
  23. plumcrazy
    53
    16,243
    Jun 9, 2003
    ALL OVER
    personally id trust ATI for MY engine.......im not gonna be a guinea pig. you never made one, dont know the cost or price and think we're gonna buy your stuff ?...eh nope
Share This Page
