Hi everyone, I need some suggestions on replacing the stock pistons for some forge ones.
First I will keep it N/A and with the stock bore and stroke. I am planning on keeping my stock rods and crank too. I am doing this now due to my engine is down and Greg Good is fixing one of my heads. I am thinking of bumping the compression to 11.5 or higher and runing 93 pump gas and some 110 racing fuel for those race days. This is the list of questions I have:
- What kind of piston manufacture should I use?
- Can I use a floating pin instead of the press fit type?
- Tips on how to deglaze the cylinders?
- Do I need to change out the rod bearings on a motor with only 12k miles?
