Power steering question
tim bob
With the car running and you take off cap power steering should you see movement of the fluid?
There are usually some eddy currents visible at idle - but not super noticeable. If someone turns the steering wheel lock-to-lock while parked and running, then you will see strong fluid movement
ViperTim
Sweden
Don't forget to buy a house for the cap so you're reducing the risk of burning down your precious automobile.
Just a fuel hose (8mm I believe, it's 10 years ago I did mine) long enough to run down by the frame rails, push it on the cap bleed n!pple and a little hose clamp on that and done. Will also be a restriction (albeit small one) of cap unscrewing itself.
Shark2th
