RT/10 Top Bolts
RobHook
Washington, DC, USA
Ok, here's the story. I took my soft top apart because it was sagging and I was going to straighten out the side bars. Well I straightened them out but while I had it apart my father used my garage to work on his car. After I was ready to put the top back together I couldn't find the bolts. So I know what they're called, sex bolts :rolaugh: but I need the sizes. They're the bolts at the back of the side bars that they pivot on. I think I'm the ONLY owner that's lost these. :smirk: It's a 1994 top by the way.
jdeft1
Metropolis
I might be able to look at mine (also a '94) on Monday... if nobody chimes in.
- Cheers
R
RobHook
Washington, DC, USA
First I clamped them to a steel I-beam (small one) and let them sit for a couple weeks. That had NO affect. I then took the entire assembly and put it in the oven at about 150 degrees for 20 minutes. (Baste regularly) That completely fixed them. The heat is the key.
And just kidding about the basting thing.
DMC94
Carson, CA
Wow. I have a spare top - gonna try the 'bake-em-straight' method !!
