Sway Bar Help Please
JohnnyViper
Massachusetts
Ok been working on my 97 GTS for the last few days and some of the things I have been doing has been a PITA but with patients all will be well. Here is my problem, I had to remove my sway bar for some of the things I have been doing and upon reinstallation I attached the sway bar to the sway bar links and tried tightening the top nut to 150 lb pounds of torque and the bottom one to 200 lb pounds of torque like my manual recommended. I took out my torque ***** and before it reached 150 lbs pounds on both, the nuts just spin in place and the resistance is almost gone, it did not feel like 150 lbs before it started spinning. Just for information the bolt is not spinning but the nut. I either striped out the nut, bolt or both and now I can not back the nut off to see what the heck is going on. Are these torque specs correct? Also is there any after-market links, I noticed one has a ripped rubber boot. Any help would be appreciated. Thanks!
Jack B
NE Ohio
I could be wrong, but, that torque value seems too high.
J
JohnnyViper
Massachusetts
the nut is half inch, my manual is at another property so I can not double check but I am 99% certain it was foot pounds
Jance GTS
Oklahoma City, Oklahoma
Front or back sway bars?
I strips the threads on my front end links and bought 2 used ones from X2 Vipers. Talk to Shannon and she will set you up! The ones I bought looked brand new and the boots were in perfect condition! Only cost me $80 for the pair!
jdeft1
Metropolis
Try a big bolt cutter to bust off the old. Maybe a dremel with a disc grinder wheel.
Chalk it up to "Lesson learned"..
cyaford
Nashville, TN
From the 1997 Viper Service Manual: Top Left on page 2-38
- 150 in lbs for the stabilizer bar link to the control arm
- 200 in lbs for the stabilizer bar link to stabilizer bar
J
JohnnyViper
Massachusetts
definitely lesson learned, i do know better but a refresher course to double check is needed from time to time, good suggestion on getting it off!
J
JohnnyViper
Massachusetts
thanks for the suggestion! :)
cyaford
Nashville, TN
I replaced my links because the rubber boots were torn. I don't see how it would be possible to remove them without damaging the boots. I had to get medieval on them just to get them out. :D
J
JohnnyViper
Massachusetts
also a tip if anyone need to take the sway bar off for the sway bar links, you do not need the "special tool" a small puller works just fine without damage to the rubber boots
J
JohnnyViper
Massachusetts
I saw, I did the hammer tactic on the first one with no success and i damaged the thread so I did a tool box dive after saying a few choice words to the sway bar and found a pretty small puller and it worked like a dream and i made peace the the bar until i screwed up on the link, now I'm mad again
Jance GTS
You can get them out with force and a big hammer without damaging the boots and threads if you take the nut and place it on the very end of the threads. Hit the nut with the hammer and you won't damage any threads and it should pop right out. I learned that the hard way :)
J
JohnnyViper
Massachusetts
good tip! :)
