doctormosfet
I see in the service manual that it states explicitly not to resurface the OEM flywheel when replacing the clutch. It says to clean the flywheel with 400-600 grit sandpaper and mineral spirits. Ok, fair enough; however, what it does not speak to is whether a new clutch on a cleaned-up flywheel will require any sort of break-in period. Any input from folks here on this?
I understand a NEW flywheel needs a break-in of several hundred to 1,000 miles (depending on who you ask) of stop-and-go driving. Arguably, a "cleaned" flywheel is a different surface and is mating to a brand new clutch pad, so I would imagine some kind of break-in would be prudent?
