That's what I have always heard. The first time i tried them at the track I warmed them up and proceeded to smoke the clutch due to great traction. I want to get drag radials for strip use for next time.
I ran 1.8 60 fts on runflats. I lowered pressure to about 24-26 psi. Also, it helps to kinda bog off the line, not too much but dont try and launch at 3k rpms or you will spin and wheel hop. And i didnt do a smokey burnout, just spun them real quick in the box to clean them off. Good luck.
Agreed. A 1500 rpm launch seemed good. Just hard to throttle on without breaking em loose bad. I think I was in the 1.9-2.0 range. Not bad but not good either.
