I've been having problems with the drivers door not opening (see other thread) and even ordered a replacement harness because I couldn't figure out my problem. I first thought it was a broken wire but after checking all the wires and making 100% sure they were all connected, I still had a flaky door switch. Sometimes it would work and sometimes it wouldn't. I finally noticed if I taped up the wires together, it wouldn't work. If I left the wires loose it worked. The only thing I can figure is with the wires taped together there's some sort of weird RF interference going on that won't let the switch work. I ened up seperating the wires into two different bundles and letting them hang loose inside the door and everything works fine.
