Will the JET-61610 skip-shift eliminator work for the SRT coupe?
Achilles99
Atlanta, GA
I need to install this on my coupe, the skipshift is annoying. Is the part the same as that on the Gen II (61610)? For those who have installed it on their GenIII is the solenoid still on the driver's side of the transmission? Can you access it without removing the metal plate?
And for those itching to type, "step on the accelerator more," you haven't been stuck in Atlanta traffic before. Sometimes, you just want to be able to shift into second while tooling along in traffic!
Nader
New York
Just spend some additional money and get a tune which will not only give you a nice seat of the pants bump in power, it will eliminate the skip shift and the car will run much cooler.
A
Achilles99
Atlanta, GA
I've already had two supercharged vipers (Roe and Paxton, 836rwhp), so the tune for 30rwhp doesn't seem like it's worth the hassle of possibly voiding my factory warranty. Any idea of the skip shift part number?
wallbanger
yea the DC performance tune eliminates the skip shift ...They can also tailor it to fit your mods
A
Achilles99
Atlanta, GA
Not motivated to install any tune (SCT, DC, etc.), if I did anything it would be to install another supercharger.
Does ANYONE know the skip shift part number for the Gen III? A lot of people think it's the same, but I'd rather hear from someone who has installed it first hand or knows for sure.
Racer Robbie
Guilford, CT-USA
Yes the 60610 will fit. So will Hurst Part# 155-0100 C.A.G.S.SKIP SHIFT KIT. Solenoid is on the driver side and you will have to remove the belly pan which takes less than 5 minutes. Total time for the job is 15 minutes on a lift. :drive:
A
Achilles99
Atlanta, GA
Did you mean to type "61610" or are you saying that "60610" will work as well?
I need a lift, which means I need a different garage with higher ceilings. Part = $30. New garage + lift = $50k. Let's see if I can justify this to my wife ;)
bluesrt
on the drivers side is correct,you do not have to remove the pan,there are 2 solinoids that look the same,its the first one,the skip shift eliminater i bought,the directions show to unplug the rear,dont do it cause its wrong,the person that wrote those directions needs his a$$wipped for being stupid!
slaughterj
Looking forward to seeing you this weekend Achilles! Didn't know you got an '06 though?!
A
Achilles99
Atlanta, GA
Yep, got back into Vipers after a brief hiatus! Looking forward to catching up with you in a few days...
A
Achilles99
Atlanta, GA
Summit Racing has the 61610 for $30, a little cheaper than the Hurst kit which is around $37. As for directions, I thought it was simply plug and play on the connector closest to the front driver's side? Anything special beyond that?
bluesrt
i believe its the same for along time,i have a 08 and installed the one from viperclub of america i think,dont really remember,looks like the same as my 94 zr-1.its just a plug n go like u asked.
Tom R
