2013 Launch Edition Performance Pages issue
Viper2442
Delaware
Looking to buy a 2013 launch edition in the next week. Current owner said he just replaced the battery and the performance pages are not working now. Anyone know if there is a way to reset this or does it need to head to a dealer. Any info would be appreciated. Thank you all.
Someone else was posting something like this recently. I don't recall exactly what was going on, but sounded like it was a UConnect update problem or something to that effect. I think you can manually update those with a USB drive (at least my parents' Challenger and Ram had that option). Might be an easy enough thing to try.
wishboneviper104
Unfortunately U connect has dropped the ball, I have called and n/g they dropped the Performance Pages if you can believe that ,wow what’s Mopar doing about it answer Nothing you would think that was built into the car unbelievable very disappointed
GTS 002
California
I used the instructions below to perform a hard reset of my UConnect. Proceed with caution and at your own risk. It didn't seem to work initially, but after a few days I tried my Performance Pages again and they worked. Odd issue I still have is only Gauges 1 page correctly displays oil temp and pressure. Gauges 2 won't update oil temp and pressure but the other readings display fine.
V
Viper2442
Delaware
I followed the instructions above and performed a hard reset. It fixed the issue and performance pages are now working normal. Thanks for the help.
ctrengine
