Parts right side window switch.
Johnz
Sioux Falls South Dakota
Looking for a new power window switch or is there a way to fix the switch. Window goes down but not up from passage side. Able to go up and down from driver's control. found the part number for 2013 SRT viper GTS. Does anyone know where to find parts? Everyone says no longer supported on back order.
SWITCH AND BEZEL. Power Window. Cross Tread Film. Right, Right Door. Part Number: 05035278AC.
2013GeeTeeS
Florida
Good luck. I spent $550 on one and at the time it was the only one in the country. I have my old one and the button broke. Yes, the tabs on the side broke. It would work once and then come out of place. I kept it to see if I could fix it. Have you taken yours apart yet to see the cause? It could be the same issue.
srcody
Reno, NV
It’s a long shot for sure, but you might try electrical contact cleaner. It did the job on my Thunderbird window switch. I used CRC QD Electronic Cleaner.
Johnz
Johnz
I have found a salvage one and should be getting it in a week or so. I have not taken the broken one apart to see what is bad. I will once I get the new one and let you know. The switch doesn't feel right when pulling it up to try to raise the window.
Johnz
Johnz
The part I ordered was a scam. I was able to contest my credit card and get my money back. When you take your switch apart can you swap the cover plate so It matches. Mine is silver for the GTS model. Just wondering if any switch will work if I can change the cover plates to match if not sliver before I purchased one.
2013GeeTeeS
Florida
I am thinking you can, but at the time it looked like more than I wanted to tackle so I left it.
Is your button broke? There are little side tabs and mine were broken. Not completely, but partially, so they would slide back into place and work one time and then slip out of the sockets.
I'd like to send my original one out to get fixed
Johnz
Johnz
I have not pulled the switch yet, it sounds like you have the same problem too. Can you glue the tabs in place? Is there someone that fixes the switch.
2013GeeTeeS
Florida
Mine is the actual button. It has a tab on each side. Not sure if a generic button from another vehicle will snap in or not. What mine was like is always a hair up at the end and it wouldn't rock properly.
Slybri
IL
Rockauto has them available. They’re reboxed OEM parts too!
Black (snakeskin-ish) bezel: WVE 1s14296
Silver bezel: WVE 1s14297
Johnz
Johnz
Had some problems figuring out how to take off the armrest. You have to lift up on the screen tabs to get the arm rest off after taking all the screws out. I do not know why I missed that yesterday. I guess sleeping on it and taking another look worked.
ctrengine
