1998 gts wiring information
jonesracing64
louisiana
I am going to repair some wiring that caught fire on a 98 gts. fire was put out very quickly. I am needing information on a wiring harness that it on the driver side at the rear of the engine. There are three connectors that are attached to the firewall. the insulation melted away in the wires. They are located about 3" to 4" below the front window cowling. nothing melted outher than the insulation. For some reasont there was fuel dripping out of small rubber line the ot metled into by the header that come from the front of the intake about 4" back from throttle body on driverside. I have not lifted car yet to see where it goes to but i suspect it runs to the gas tank. Unlees i am incorrect i think it is either a vent of vaccum line and should not have fuel in it dripping. thanks for the help
I have a full service manual for a 1998 which will help biggily on your project.
If you can state the color coding on the insulation to the wires that is still intact.
