GTSnake
So that's $2k for the AEM and another $900 for the pro racer package?
How does that compare to the Pro EFI that I've heard about?
UPDATE: Replaced o2 Sensors, problem still there....
Raised o2 sensors out of exhaust path (1" spacers)..problem still there.
Disconnected o2 sensors completely, made sure vec has a/f's @ 14-15:1 cruise and problem solved...no more flat spot! Hmmmm 02 sensor issue, or PCM issue. Seems PCM response time or some sort of a/f adjustment happening.
Yeah, are you talking about "at cruise" or "in acceleration" now. Also, when you said "disconnected 02's", did you unplug sensor or take it out of exhaust pipe so it's getting a downstream "fresh air" reading?? any error codes?
So what he was saying, is that under cruise (closed loop), all is well (yet, he said "problem solved")?. That's what confused me was the "problem solved" part at cruise. But, does that "solve problem" at acceleration ?. (now I'm really confused)
Nevermind, I think I know what he was checking a/f at cruise for now.
Daniel,
I have the same issue. If I accelerate slowly, the car will go very lean in one spot at low RPMs which results in a flat spot in acceleration just as you describe.
Do you know if this is consisent enough in the stock mapping to just offer a set tune to fix it with the SCT or is each car different?
If I man up and get the programming module, what all can I fiddle with? Can I correct the temperature compensated fuel offset rather than upgrading to a VEC 3?
I can't find an example of the SCT programming interface. How easy it is for someone that basically knows how to tune a VEC? Any screen shots available or list of available programmable functions?
Since these are locked to the PCM SN are there any issues with programming a '96 PCM in an '01?
Do you know of anyone that has completely replaced the VEC in a Roe SC setup using just the SCT programming on the stock PCM? Can the PCM directly handle the bigger low impedance injectors?
Thanks,
--- Ken
I am running the '96 for correction of erroneous misfire codes. Can this be dealt with on the SCT if I put the '01 back in to get the other benefits?
I'm really starting to like the idea of this approach. Since I haven't been able to munch my cast pistons after a couple of years with 6.5lbs and a VEC2, I'm beginning to think I need more things to play with that I can screw up![]()
Hmmm the SCT route sounds like a good idea. The only downside that I can think of is getting the right tune if you're not familiar with tuning your own car.
Just to explain
As VS stated, once you unplug the (front) O2 sensors, the car will not go into closed loop, so technically you are cruising / accelerating in Open loop the entire time. So with your Open loop map, you would normally run fairily rich is some areas, so to compensate for this I tuned my vac fuel map (vec2) so that it was 14.7 to mimic closed loop (trying to compare apples to apples fuel-wise). Problem / flat spot was not apparent anymore.
Hope thats easier to understand
Dan - Can you fix this responce rate in the PCM if a PCM is sent to you?
Dan, which scanning software do you recommend?
Just to explain
Can't we just use the VEC logging feature?
What would removing (not disconnecting) rear o2's do? I've got a 98 w/6.5 Roe, B&B's, RR's, no cats. If LC-1 is accurate (seems to be), I run rich (11.5-13.9) at 1800-2200rpm cruise. Sean said (if I understood him correctly) that w/o the cats, the rear o2's may not be getting a big enough difference in sensing to make adjustment in PCM. ??? Again, I don't want to be mis-quoting Sean, I may have just misunderstood him. And no, I haven't gotten opportunity to disconnect rear o2's OR any datalogging yet. Soon though, I hope. Thanks guys for sharing ya'lls expertise
Hmm, switching between simms and rear 02 sensors causes complete tune changes on my car. Carpping out past half throttle? Switch rear sensors and a while later it'll run OK. Etc. Weirdness.
Ted
Ted
Dan, Do you think Drilling out front o2 sensors would help response time (STFT) with the closed loop situation?
