'01 ABS, Two or Four Stage?
Paul Fischer
Texas, USA
\'01 ABS, Two or Four Stage?
Is the ABS system on the 2001 a two (front and rear) or, as I expect, four stage (independent on all four wheels) configuration?
Bob Woodhouse
Fort Worth, Tx.
Re: \'01 ABS, Two or Four Stage?
Actually it is a three stage, or three seperate inputs if you will. Each front corner is on it's own and the rear is done as one. Not the absolute end of the high tech world.
P
Paul Fischer
Texas, USA
Three stage should eliminate flat spotting. I suppose if anyone feels the need for a full on four stage system the Archer system fills the bill. Thanks Bob. And what's the verdict on that trick World of Outlaw's setup on your race car?
Rich Carlson
N. Richland Hills, Tx
Its more commonly call "channels" and Bob is correct, there are three of them. Three channel systems are very common when it comes to ABS.
