04' HID Bulb Question
dsg03svt
San Antonio
I'm considering switching out my stock HID's for either a 6000k or 8000k bulb. I have an 04 and it says on both plasmagarage and sylvania's website that 2001-2004 have the 9006 bulb type. The 05-06 have the "HID-D1S" bulb type.
Is this a mistake?
I need to know which bulb type to order.
Cape Coral, FL
Yes, thats a mistake. The 03-09 headlights are the same.
The 9006 and D1S are BOTH contained in all SRT housings. The D1S is the Low/High beam, and the 9006 is the halogen High beam "back-up"
D
dsg03svt
San Antonio
Thanks!
You don't happen to sell replacement HID bulbs do you? You've answered quite a few of my questions in the past and I'd assume to give you the business if I could help it.
Cape Coral, FL
Thanks!
Hello,
Unfortunately, aftermarket lighting is generally sub-par on quality, so I tend to avoid most aftermarket lighting systems. The OEM's would never install an 8000K+ system, and as a result, the companies making them are generally not the same companies as the OE parts. Lots of bad bulbs and ballasts out there. I would recommend purchasing from someone local so you have recourse if you end up with a bad bulb.
