08 Belly Pan
wormdoggy
Toronto, Ontario
Does anyone have a picture of the belly pan on the new 08's?
Or a picture underneath the car.
I would like to see if the cut out for the crossover piping has been eliminated and the only the scoop cut out for the differential remains.
Patrick
W
wormdoggy
Toronto, Ontario
Looks great .....entirely different belly pan configuration.
Still has the scoop for cooling though.
Patrick
2002_Viper_GTS_ACR
Charlotte, North Carolina
Only has the scoop for cooling the Diff, not the exhaust manifold. And I dissagree, it looks pretty much "stock" 03-06, other then the elimination of the cross over 'window shield'
If I was a betting man, I would say it probably bolts right up to an 03-06 that has gone aftermarket with their exhaust and eliminated the stock cross over.
Kenny
You can also just rivet a piece of aluminum over the crossover window if you aren't using it.
SKY1960
