17's >>>>18's
sparty116
Michigan
17\'s >>>>18\'s
Probably a real simple question, but I'm looking at getting a set of OEM 18" w/335/30/18 viper rims from a later gen II and was wondering if they are a direct replacement and will not require a speedo recalibration. I did aquick diameter calculation and the 18's come out to be slightly shorter by like ~6mm. Is this within the realm of error on a speedo and tire inflation etc....
ruckdr
Renton, WA USA
Re: 17\'s >>>>18\'s
Minor difference; use the following to calculate the actual tire diameter:
TIRE DIAMETER CALCULATION
Tire Diameter = (Width x Aspect Ratio) / 2540 x 2 + Wheel Diameter(inches)
Where: Width is the first number in size (i.e. 225)
Aspect Ratio is second number (i.e. 55)
2540 is the conversion factor to inches
Wheel Diameter in inches
Example: 225/55 x 16
225 x 55/2540 x 2 + 16 = 25.74 inches
225/45 x 17
225 x 45/2540 x 2 + 17 = 24.97 inches
345/30 x 19
345 x 30/2540 x 2 + 19 = 27.15 inches
335/30 x 18
335 x 30/2540 x 2 +18 = 25.91 inches
You will like the newer wheels. See some pictures in my Photo Gallery (click Photos under my Avatar) go to page 2.
Later,
