2008 question around performance mods
drasch21
Imperial, MO
Hey all,
Recently stepped into a 2008 viper. Bone stock.
I am wanting to do
Belanger full exhaust(headers/catback/highflow cats)
5th gen intake
DSE catch can
I live in missouri and they require an OBDII "ready state" scan to pass emissions.
Will this setup work on the car without throwing CEL/MIL?
If not, what are the options for making it work?
Thanks!
redtanrt10
Dana Point CA
On top of that you need to get the Mopar Venom controller
With the headers, it's when, not if they will throw a CEL. Before going to emissions testing you'll need to, swap out the controller to the stock one, then clear the codes, then do the correct driving cycle so that the emission system reads "ready". You must drive the car with high RPM's and don't lug the engine or you'll trip a CEL Good luck!! Mike
drasch21
drasch21
Imperial, MO
Torrie from hp tuner says he handle this via the HP tuner module. Seems reasonable?
Dan Cragin
LA, CA
I have been able to get these cars to pass the emissions monitors with the stock controller. The upstream O2 sensors need to be relocated to collector, a CA approved or secondary production catalyst used and the downstream sensors mounted behind the catalyst with proper shielding.
Kevin M Melisz
Buffalo, NY
Hi drasch21, I recently put on a full Belanger exhaust on my stock 08 with stock controller. I have about 500 miles on the car without throwing any CEL/MIL.
I would be happy to discuss the project.
treesnake
St.L
Hey all,
I am wanting to do
5th gen intake
DSE catch can
Thanks!
Go to see Steve Hemann at Hemann Automotive. He's on Jeffco, north of Richardson by the train tracks and Arnold police station. He has three Vipers himself and takes care of lot of the StL Viper people. He will tell you what is needed in Jefferson County.
