2009 ACR ******** For Sale "New"
BJ MOTORS
Tomball, Texas Usa
2009 Dodge Viper SRT10 ACR – 1B3JZ69Z19V500474 - $107.170.00 – Just landed this 2009 Dodge Viper ACR Graphite “********” Viper. Long awaited and beginning to roll in are the Graphite ACR’s., This 2009 Graphite SRT 10 ACR is equipped with ********* Package, The standard ACR is 40 pounds lighter than the regular Viper coupe. An optional "*********" pack saves an extra 40 pounds through the removal of the audio system, underhood silencer pad, trunk carpet, and tire inflator. The radio is replaced by a lightweight cover that can be configured to mount the lap timer that comes with the package. Hard-Core.Graphite Black Dual Ban, Driver Stripe Delete, “Brand New” never titled ACR for 2009. The Graphite is absolutely stunning. These cars are selling as fast as I can get them into inventory. The most desirable and incredible car out proven to be the fastest car running the Ring at 7.22 beating the most incredible super cars in existence. Here are the specifications of the car. Don't wait it will not last long. This 2009 Dodge Viper ACR is being offered for immediate sale. I also have other 2009 ACR’s in stock for immediate delivery. For more information call me on our 800 toll free number 1-800-270-1608 or by e-mail at [email protected] . The Viper ACR is raw.
Details
More Details The ACR has exactly the same power and torque as the regular Viper-600 horses and 560 pound-feet. The engine drives through a smaller dual plate clutch that reduces rotating inertia by 18 percent and the latest iteration of the Tremec T6060 six-speed that includes triple-cone synchros on first and second, and 10-percent-wider gears to manage the torque. The new GKN ViscoLok diff features its own sump to quicker generate the hydraulic pressure needed to actuate the limited-slip clutches faster, yet more progressively and with greater precision.
Most of the time, effort, and development dollars have been spent on stuff that makes the ACR go faster through the twisty bits-suspension, brakes, wheels and tires, and aerodynamics. Especially the aerodynamics. Just chew on this for a moment: At 150 mph, the regular Viper coupe generates 100 pounds of downforce; at the same speed, the Viper ACR generates 1000 pounds of downforce.
That giant carbon-fiber rear wing is the most obvious reason why. But there's also a new carbon-fiber front splitter that extends way back under the car and incorporates seven steps to diffuse the airflow. The new hood louvers unveiled with the 600-horsepower engine upgrade a year ago play a part, too. "We knew we were going to do a new ACR, so we moved the louvers forward to help change the aero balance of the car," says SRT boss Herb Helbig.
Suspension changes include race-style KW shocks all around that can be adjusted for stiffness and ride height, springs twice as stiff as those in a normal Viper, and a beefier front stabilizer bar. Forged "Sidewinder" alloy wheels save 30 pounds of unsprung weight, and new two-piece StopTech brake rotors save a further 30. Michelin Pilot Sport Cup tires-basically ************ race rubber-are standard.
The standard ACR is 40 pounds lighter than the regular Viper coupe. An optional "*********" pack saves an extra 40 pounds through the removal of the audio system, underhood silencer pad, trunk carpet, and tire inflator. The radio is replaced by a lightweight cover that can be configured to mount the lap timer that comes with the package. Hard-core.
General Body Style - Coupe
Assembly Plant - Conner Avenue (Detriot, MI)
EPA Vehicle Class - Two-seater
Engine Type and Description - 10-cylinder, 90-degree V-type, liquid-cooled
Displacement- 8.4 liter (510 cu. in.)
Bore x Stroke - 4.055 x 3.96 (103 x 100.6)
Valve System - OHV, Variable Valve Timing, 20 valves, roller-type hydraulic lifters
Fuel Injection - Sequential, multi-port, electronic
Construction - Aluminum alloy block with cast-iron liners, aluminum alloy heads
Compression Ratio - 10.2:1
Power (SAE net) - 600 bhp (450KW) @ 6100 rpm (71 bhp/L)
Torque (SAE net) - 560 lb.-ft. (760 N•m @ 5000 rpm)
Max. Engine Speed - 6,250 rpm
Fuel Requirement - Unleaded premium—91 Octane (R+M)/2
Oil Capacity (with filters) - 10 qt. (9.5L)
Coolant Capacity - 16 qt. (15L)
Emission Controls - Four three-way catalytic converters, heated oxygen sensors, engine internal features(a)
EPA Fuel Economy (city/highway) - N/A (a)Meets Tier 2 standards in all 50 states.
Electrical System Alternator - 180-amp high-speed
Battery - Leak-resistant, maintenance-free, 600 CCA
Radio - AM/FM/CD radio with MP3 disc play capability, with 310-watt RMS audio amplifier and seven speakers
Transmission - Manual Six-speed Overdrive Description - Synchronized in all gears, electronic 1-4 skip-shift and reverse lockout mechanisms Gear Ratios
1st__2.66
2nd__1.82
3rd__1.30
4th__1.00
5th__0.74
6th__0.50
Axle Ratio - 3.07
Overall Top Gear - 1.5
Final Drive Description - Frame-mounted hypoid bevel gear with GKN ViscoLok speed-sensing limited-slip differential
Dimensions and Capacities (measured with 2 passengers) Wheelbase - 98.8 (2510)
Track, Front - 61.6 (1565)
Track, Rear - 60.9 (1547)
Overall Length - 175.6 (4459)
Overall Width (at sills) - 75.2 (1911)
Overall Height - 47.6 (1210)
Ground Clearance - 5.125 (130)
Curb Weight (estimated) - 3,408 lbs. (1552 kg), ACR; __ 3,366 lbs. (1533 kg) ACR with ********* (Audio Delete) Package
Weight Distribution F/R - 49.5/50.5
Frontal Area - 19.3 sq. ft. (1.79 sq. m)
Fuel Tank Capacity -16.0 gal. (70L)
Accomodations Seating Capacity - 2
Head Room - 36.5 (926)
Leg Room - 42.4 (1077)
Shoulder Room - 54.1 (1375)
Seat Travel - 7.6 (192)
Recliner Range - 45°
SAE Interior Volume - NA
Body Longitudinal front engine, rear-wheel drive Construction Backbone tubular space frame with separate cowl structure. SMC and RIM body panels, aluminum sills, RIM front and rear fascias with composite impact beams
Aerodynamics Front - Carbon fiber ‘fanged’ splitter with rub strips; splitter extension; carbon dive planes
Rear - Carbon fiber ACR wing with 7-position adjustable stanchions
Downforce @ 150 mph (high down force set-up) -1000 lbs.
Suspension Type - Four-wheel independent with high-performance aluminum control arms and knuckles, and KW Suspensions 2-way adjustable competition coil-over shock absorbers
Front - Cast-aluminum unequal-length upper and lower “A” arms, high rate coil springs, gas charged 2-way adjustable monotube shocks absorbers, high rate stabilizer bar
Rear - Cast-aluminum unequal-length upper and lower “A” arms, toe-control links, high rate coil springs, gas charged 2-way adjustable monotube shock absorbers, stabilizer bar
Steering Type - Power-assisted rack and pinion
Overall Ration - 16.7:1
Turning Diameter (curb-to-curb) - 40.5 ft. (12.34 m)
Steering Turns (lock-to-lock) - 2.4
Tires Size and Type - P295/30 ZR18—front, P345/30 ZR19—rear
Manufacturer and Model - Michelin® Pilot® Sport Cup with low-pressure sensors in valve stems
Wheels Type and Material - Lightweight forged aluminum ”Sidewinder”
Size - 18” x 10.0”—front, 19” x 13”—rear
Brakes Size and Type - P295/30 ZR18—front, P345/30 ZR19—rear
Art 138
Davie,FL
It seems the price has increased since I purchased mine, is that correct?
Curious what were the prevailing prices in 08??? or at least a range in price??? Most of the new ones out appear to be in the 108 thousand price......
Cindi Lux
Portland, Oregon
That car rocks. Everybody should have one of those in their garage or on the track. The thing that really impresses me is the downforce numbers. Unbelievable for a street car.
Bernie- that thing should be gone soon.
Brad04Mamba
Fresno, California, USA
Looking at your avatar you did not get the driver stripe, that adds around $1600 I think.
Yeah, and Nav added another $1800 or so, but I think the prices did increase, the most expensive 2008 was in the $104 range, now they are getting up to $108. There must have been a price increase.
Mine was $100,480, you could add $1600 for driver stripe and $1800 for Nav. What other options were there?
Janni
Raleigh, NC, USA
I ordered mine in October 2008. Seems to have been about a $5K price increase between then and now.
BlknBlu
Omaha, NE
I hear thru the grapevine that he has a lot of ACR's on order.
they should sell quick.
Bruce
adamlotus
los angeles
great color combo i would love 2 see that car go for sticker will make me feel better about my buying exprience and hold values down the road .that is one bad ass ride.wish i had the dough.
B
BJ MOTORS
Tomball, Texas Usa
There is a total of 60 cars ordered. 5 Arrived today, 3 have been sold. The colors that came in today were 2 Graphite's both ********, one Black Red Driver's Stripe, and a Yellow Coupe that is sold. The Yellow ACR's should be here very soon since the Yellow Coupe has arrived.
B
BJ MOTORS
Tomball, Texas Usa
Now I have three ACR's ready for delivery:
Black ******** with red Driver's Stripe
Graphite ******** with driver's Stripe
Inbound this week Two Yellow/Black Duall Ban Standard
Call While they are here.....
Boxer12
Colorado High Country
"The radio is replaced by a lightweight cover that can be configured to mount the lap timer that comes with the package." I have been curious about this. What kind of lap timer? AMB?
Catwood
Is that the one Woodhouse sold new?
I really wish I could have afforded the ACR. But for 30K more I just couldn't do it..
FikseGTS
South Florida, USA
My 2008 was $104,365
$86,295
$12,050 - ACR
$1,650 - Driver's Stripe
$1,790 - NAV/Sat Radio
$1,700 - Gas Guzzler
$880 - Destination Charge
I think the other option was the protection package (car cover).....
jpolen21
