Hoodoo Man
I'm doing a coolant change on my 2010 ACR. The front belly pan needs to be dropped. Have any of you 2010 ACR guys removed the front belly pan?
I have removed the 4 belly pan to frame bolts, and the 4 belly to wheel housing screws. It looks like I need to remove the 4 front-splitter cable bolts (4 mm hex) located on the underside of the belly pan (located toward the front of the belly pan next to the front splitter)?
Are there any complications in removing the 4 front-splitter cable bolts? When they are reinstalled, what is the torque spec?
Are there any rivets that need to be removed?
Seems like a lot of hassle could have been averted by using a trap door under the drain petcock!!
Any help would be greatly appreciated.
P.S. I love the ACR!!
Larry
Larry
