3.55 Gears.....not doing the Speedo?
Andrew2KRT10
New York, where else?
What would be the result if I don't do the Speedo? I know the speedometer will be off but which way and will it be a constant change? I know I should figure this one out.....but.......
Thanks,
Andrew
GTSnake
Motor City
So can you adjust the box to read the other direction where it will give you half of your speed as if you were simulating a 1.535 ratio? That way your odometer would spin half as fast. ;)
ctrengine
