99 GTS Side Cat and Muffler Delete
7TH_SIGN
Virginia
Stock 1999 GTS ACR
Started off by deleting the cats by installing the ROE cat delete. Sound was still a little too quiet for my taste (No raspy drone sound, just a little louder from stock). So I decided to remove the side mufflers. I got one ROE pipe off the muffler but the other one refuses to come off.
I am now looking to just have a straight pipe done. I measured pipe to pipe and it's 40.5".
Recommendations for a place to purchase the pipes or have them fabricated? Also the best option for clamps. I know welding is best but I can't weld.
Thanks!
speedracervr4
Lancaster, PA
I would have left the resonaters (thing removed) and removed the mufflers in the rear. The resonators do a good job of controlling the drone. Any local exhaust shop should be able to get you the pipes you need fairly cheap.
VIPER GTSR 91
Spring, Texas
I had this same set up on my old 99 GTS. Call Lou Belanger and he should have a straight pipe for your needs. Google Belanger Viper to see his site with phone number.
Indy
Vancouver
It will be pretty loud with just straight pipes all the way through. I deleted the rear muffler and put some bullet mufflers in the side. Also running magnaflow high flow cats. Plenty loud for me, but everyone has a different ear for volume :) Any exhaust shop can weld in the pipes that you need.
Indy
Vancouver
Just realized that you're not deleting the rear muffler, so it shouldn't be that loud...
7TH_SIGN
Virginia
Perfect. Just what I was looking for. Thank you!
Yes sir, still have the rear muffler.
viper k
if your putting straight pipe see if you can get chamber pipe they put then on corvette side pipes and 69 camaros !!!!!!!
7TH_SIGN
Virginia
Decided to do it all on my own. All parts were found at local car part stores. Very happy with the sound and performance. Car feels alive now. Cost me around $85.
SRToad4
What parts did you use exactly? Also, what did you use to cutoff the stock stuff?
speedracervr4
Lancaster, PA
Read about this but couldn't find a write up or parts involved.
It was on here, but I guess it is under "members only" section. I copied and pasted an insert I saved. You drill out the holes with the bit then use the rivet nut tool with the proper size rivet nuts. I got the tool from Northern tools. I didnt use all the washers on the list.
[FONT=&quot]List of tools/parts for Viper sill modification: [/FONT][FONT=&quot][/FONT]
  • [FONT=&quot]18 ea. steel rivet nuts size 10-32 cad plated[/FONT]
  • [FONT=&quot]6ea. stainless #10 flat washers, 1/2 in. o. d.[/FONT]
  • [FONT=&quot]12ea. stainless #10 flat washers, 3/4 in. o. d.[/FONT]
  • [FONT=&quot]18ea. stainless #10 lock washers[/FONT]
  • [FONT=&quot]18ea. stainless #10-32 x 3/4 in. stainless button head machine screws[/FONT]
  • [FONT=&quot]19/64in. drill bit[/FONT]
  • [FONT=&quot]Marson thread setter tool[/FONT]
7TH_SIGN
Virginia
Thanks a lot Speedracervr4!
Used a sawzall. Purchased these parts:
10ft of 2.5" Aluminum Piping
Two 2.5" to 2.25" Exhaust Pipe Reducers
Two 2.5" Exhaust Pipe Adapters
Four 2.5" Torco Easy Seal Clamps
Two 2.25" Torco Easy Seal Clamps
Two 2.5" Clamps from Aluminum Pipe to 2.5"/2.25" Reducer (Not Pictured)
High Tempature Exhaust Silicone Sealant
SRToad4
How long do you think the whole project took you? What brand high temp sealant did you use? I will be tackling this within the first month of owning the GTS for sure :)
Also, how hard is it to remove the factory side sills?
7TH_SIGN
Virginia
I would estimate total hours of actual labor to be around 3 hours if you know what your doing and have all tools and parts required.
I took my time because it was the first time removing the side sills and reinstalling them. Straight forward process. I called multiple shops in my area and they were all giving me a labor only estimate of $500, that's with welding.
Hardest part was getting the clamps air tight. Which is why I used high temp sealant. If you make sure you have little to no exhaust leak, you wont smell any fumes while driving the car.
Permatex Muffler & Tailpipe Sealer was the best I could find at local shops.
*********I got some *** in regards to this.**********
I did use a clamp where the 2.5" aluminum pipe meets the 2.5"/2.25" reducer. It is just not in the picture. I didn't need it because I was able to get the reducer extremely tight and secure on the pipe, but added a clamp anyways.
Make sure when you place the clamps on the pipe or reducer, you line it up so that all pressure is being transferred to where both pipes meet, rather then where the reducer/adapter end/start. This will insure the best seal possible.
SRToad4
Can you post a sound clip of the exhaust? I'd love to hear it!
Does it sound "tinny" at all!?
steve e
I did the same mod, but you will also have to get the Mopar Off Road ECU, or the check engine light will come on. The off road ECU is not looking for the rear O2 sensor for Cat efficiency.:2tu:
7TH_SIGN
Virginia
Yeah if it comes on I will get the O2 simulators. Still hasn't come on even though its a 99.
Sound clips are not that great, you really need to hear it in person. I will try and get some with my Canon 60D. No tinny sound.
SRToad4
Can't wait to hear some sound clips, so excited to do this mod!
SRToad4
Stock mufflers? Can't wait to do this, maybe even next weekend :)
SRToad4
Perfect, I'll post a thread when I do mine with pics/vid as well :)
7TH_SIGN
Virginia
I deleted the rear muffler yesterday. The car now is way too loud for the streets (as expected). Can anyone recommend a good side resonator?
SRToad4
Did you like how it sounded better with just the side cat and resonator delete? Might do it this weekend.
7TH_SIGN
Virginia
Yes I did. It was loud but still tolerable. With no mufflers/resonators/cats, it's way to loud. Sounds like a monster but just too loud.
I may just add the side resonators back on.
7TH_SIGN
Virginia
On deceleration (with no cats, no resonators, only rear muffler) the car sounds a little funny.
I think optimal setup (using stock components) would be cats and rear muffler removed.
Going to do this next.
SKY1960
