Tom F&L GoR
I have a batch of rear brake calipers apart and being machined, so now is the time for powdercoat requests. For a short time, an extra $99 gets the calipers powdercoated in your choice of color.
Your total cost:
$99 + $660 + cores returned ($759)
or
$99 + $999 and you keep the cores. ($1098)
These rear brakes offer the least expensive and easiest alternative to better braking for the non-ABS Viper. They are a simple 2-hour remove-and-replace job for the average mechanic. You can re-use all your other components: pads, hoses, attaching hardware, and they will fit under all year and size Viper wheels.
Test results with a 1994 RT show the simple swap to 40mm calipers provide over 1.0 G deceleration rates (with street tires and OEM front brakes.) You'll avoid getting flat spots on the front tires because they provide balanced braking for street, autocross, and track use.
Lots of info at 40mmBrakes and if you have any other questions, let me know!
Your total cost:
or
