ceokris
I've just started getting into A/C systems on vehicles. The other day mine completely stopped functioning ('97 GTS) after my battery went dead., I have a rough idea on how they work but I wouldn't think the battery going dead has any corrolation to the A/C system. Here are the symptoms:
No A/C on any settings. Visually inspected the A/C compressor clutch and it is not engaging ever. The radiator fans do not kick in on any of the A/C settings (which they use too immediately). System blows hot air. However, the system appears to be cycling through the vents properly (ex.. defrost, foot air, vents on the selected settings, and OFF works
Here is what I have tested:
Manually bypassed the A/C clutch relay and the A/C clutch does engage (only tested for a short period of time to prevent damage). So A/C clutch works!
Visually inspected the looking-glass on the AC canister and I do not see any bubbles, actually its crystal clear. So I am assuming its got a full charge.
My real question is, what tells the A/C to start operating? I'm not at WOT, and I'm guessing that disengaging system is tied to the throttle positioning sensor. Or is something telling it to NOT operate, like if there is absolutely no refregerant in the system and there is a sensor for that. It was working perfect the other day, and today it just doesn't want to enable.
BTW, I'm still waiting for my shop manual - if it's anything like the others, I'm guessing it will have little or no information on the air condition system.
Thanks in advance.
-kris
Thanks in advance.
-kris
