Matt M PA
The weather was great this weekend in SE PA and a perfect opportunity to use the GTS.
I got to my destination, but when I pulled the inside door handle, the door did not open. I used the emergency release.
When I returned home, I removed the finish panel by the door on the outside(the body colored part in front on the door), and pulled the rubber boot from the door and body that holds the wiring that runs to the door.
There was a wire broken clean through...just like when the speaker stopped working. I stripped each end, then carefully worked a new piece of wire through the rubber piece, then soldered each end. The soldered areas were placed in the door and body so that they would not be subject to flex. Viola..door opens.
Just a reminder if something should stop working in one of your doors...look there first.
