V10 ACR
Hi All,
After driving the car for 2 years and 15,000 miles I have finally decided to play with the adjustments for the shocks. I pulled the front wheels, found the Bump and Rebound adjustments and went to set them to full soft. I used an awl that fits perfectly in the hole. Neither the Bump or Rebound will move more than one notch, and that is only when I use a lot of force. It is the same on the right and the left side. It feels like there may be some grit or fine sand between the adjustment disks. I tried a firm water spray and got them clean, but still I can't seem to get the disks to move. What am I doing wrong? Is there a lock somewhere that has to be depressed to get them to move (It's a 2000 ACR with the Koni 2812's) ? Any advice? Thanks.
