Air conditioner running air only coming out of top windshield vent. Controls not working
brianbut
san diego ca
1998 GTS. 71k
Problem
The heat and a/c do work but the control knob is not redirecting the air to the front vents
Any suggestions or recommendations
Brian
San Diego
28G
Baltimore, MD
Yeah it is a pretty easy fix - I had this happen last summer, it was a screw that had backed out of vacuum actuator linkage.
The vent doors for heating/cooling and vent selection are controlled by a few vacuum actuators, two of which are under the dash on the passenger side. There is a plastic kick panel with a few screws, pop those out and then take out the panel and you'll see some vacuum lines and the two interior actuators. On my car, the screw holding the linkage to the two position actuator had backed out, and it defaulted to the defrost/windshield vent setting. It is possible you've got an issue with a vacuum line coming loose or leaking, but screw backing out more likely.
B
brianbut
san diego ca
Thank you for your note
I will look into your solution
Have a wonderful day
Thank you again
Brian
Check Vacuum source first since its easy, may have become disconnected.
cookviper
