Aldan Billet Aluminum Shocks
Joseph Dell
Atlanta, GA 30338
As long as they don't leak in the 1st 50 miles, you are good. they don't use a C clip on the adjuster knobs so they sometimes blow out when pressure is first applied. I love them, but others aren't huge fans.
cheaper than motons or penske...
JD
Joseph Dell
Atlanta, GA 30338
knob is for stiffness. the adjustment for height is done w/ the shocks on the car with those round adjustment thinggys that are standard for adjustable shocks.
kwkshift
Scottsdale, AZ
JD
I noticed that there is one know with even numbers and the other has odd numbers on them. Where should these be set for a street/ strip car? I have looked on the Aldan website, but I can't figure it out.
Thanks!!
ROCKET62
Has Left the Room!
Phoenix, AZ bye-bye IOWA
There have been far more negative/problem posts than positive feedback. I dont recall seeing any newer posts or indication that they have made any changes to address the issues with leaking.
TexasPettey
Austin, Texas
I have them on my Gen1. They seem to work pretty well. Adjusting the ride height is a bit of a pain. It's very problematic to do with the shocks on the car. It's easy to take them on and off, however, so you can adjust the height off the car. If you're only going ot do it once, not a problem.
SKY1960
