Antifreeze leak?
Limit
1996 GTS:
My antifreeze is leaking out onto my garage floor... It has for over a month now but the antifreeze looks fine in my tank. It doesn't seem to come close to running low.
I took it into the shop to get the oil changed and to look everything over and he didn't seem to think anything was wrong with any fluids. Any suggestions?
L
Limit
front. about halfway between front bumper and middle.
1TONY1
Dalton Ga. (Chatt. Tn.)
If it is around the front right area, there is a screw that sometimes wears into the coolant tank. This tank is in front of the passenger front tire.
You need to park it on jackstands or a lift and follow the trail ;)
Put the car on a lift and go over it CAREFULLY...and, if you are using "green" coolant, get a 50 watt UV light ( Snap-On makes one...appropriate goggles help) and look around...bet you find the source.
RedEnuf93
Lancaster, PA
I seem to have similar problem, what it looks like is waterpump leaking. The bolts are wet, dripping... Most everything is wet, so difficult to say where it started...
New pump next week.
Venomiss
Guest
1996 GTS:
Have you found the source yet? Let us know what it is.
joebrett
