Any msd boost a pump install photos
mntngts99
Boise, ID, USA
I didn't take any pics when wiring to the fuel pump. This is all I have.
SYNFULL
Bucks Co, Pa
I know it's been a while. Can you tell me where you accessed the fuel pump wiring. Did you have to remove the rear driver wheel well to get to the wiring? Also do you know the colors of the wires? I have been having a hard time finding any info on this.
Gary
mntngts99
Boise, ID, USA
I pulled the carpet off the rear deck. There is a round access cover on top that I removed to fish the wires up to the fuel pump and wired it direct.
BOTTLEFED
Pocatello,ID
Is there a reason not to put it in the rear closest to the fuel pump?
it seems the important wires would be shorter and you have a closer run to the battery
I've done fuel pump rewires in the past on other cars and I use the stock wiring to the pump to switch on the relay
therefore, on the BAP, you would only be running a vac. line from the engine bay
I'll be installing mine soon and will try to remember to do a full writeup
VinhyVegas
