Anyone Autocrossing a Gen 3
JohninFL
anyone autocrossing a gen 3?
I would like to stick to using the stock runflats(since its all local fun stuff) in the 18/19 stock rim combo mode and a track alignment would probably help. (do gen 3's have the removable shims?)
any recommendations for specs on a autocross or track alignment for a gen 3?
any opinions on proper pressure for runflats at autox?
any news on sticky tires in 19" (that don't require time to heat up) so I can stay in SS class ?
(move to 18's all around takes me out of stock and bumps me to ASP)
Saratoga,CA
At our Skip Barber "Viper Club Driving School" we were allowed to drive our cars on their autocross course to compare our Vipers with their School cars. Tire pressure suggested is mid to upper 30's depending on track conditions and temperature. After a run look at the tire edge rollover, no rollover lower PSI, 1" of rollover increase PSI log times to compare to tire PSI. Some drivers do better with a little oversteer. SRT10's are a blast to autocross.
Most important technique, look ahead by a couple seconds. As you start to turn-in(for a turn) you should be looking at the track-out or next turn depending on the track layout.
Have fun!
