Anyone ever have the rear window on a gts
happy
p.e.i canada
rattle when u have your windows up?? seems like when you get to a certain speed and hitting little bumps on the roads I can hear like that back window rattling a bit,, anyone ever have the same issue? if you did what did you do to fix it? thanks!
Stonep185
Ft. Worth, TX
I adjusted the bump stops on each side of the car where the glass rests. Check the hinges of the glass to be sure the glue hasn't let go. Also check your glass struts for rattling.
H
happy
p.e.i canada
Will do sir thanks !! It sounds like its rattling right around the pice that locks
GTSnake
Motor City
Make sure your vents in the rear corners aren't blocked. It will build back pressure when the windows are down and eventually loosen the back glass.
