Anyone in Houston have a Brake Tool I Can Borrow
AJT
Houston, TX , USA
I am going to change my pads this weekend, anyone have a tool I can borrow?
Andy
AJT
AJT
Houston, TX , USA
I have an 02 RT/10, I was told this takes a tool. I will go ahead & order tool with EBC greens. I have done 20-30 ford brake jobs & 20 -30 Chev. jobs, but never a Dodge.
Is there anything special I need to know about doing a Viper brake job?
Do the pistons push in like a GM, or do they twist in?
Is it better to use a floor jack, or jack provided with car on lift points?
Any other tricks to it?
I read on an earlier
post that the torque setting is 90 - 100ft lbs. Is this right?
Thanks for the help
Andy
ryan 94RT
SMYRNA GA
Andy
I just did my 96 gts pads and changed the brake fluid. The job is easy and shouldnt take long at all with all the other times you have done pads.
1 the fronts are easy just pop out the pin push in the calipers
and put new pads in.
2 the rears use the tool or a the needle nose and turn it back in . i think it went in clock wise.
3 the torque is 90-100 i go to 100 for track use.
hope all goes well.
2002graphiteviper
Minneapolis, Minnesota, USA
Just use a different tool... I too got suckered into ordering this tool - for a whopping $40 or $60 - it arrives - and I laugh...
If you want - I could send mine down to you - but I have a feeling that you could make something else work... Plus - after shipping - then we would have wasted even more on this precious little Viper tool...
Oh, just remembered, the tool has a name - and any tire shop should have the tool... Sorry, can't remember what they called it... But they did tell me that every shop should have one - see if you can borrow it from a shop for a while if nothing else works...
cstegall
Fort Worth, Texas USA
Andy,
I received one of those tools when I got my EBC's from JonB. Let me know and I will send it down to you and you can send it to my Houston office when you are through using it.
Let me know if I can help.
No Flame Intended...Just Observation,
CStegall
picflight
Granada Hills, CA USA
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by 1TONY1:
I made one using a socket, just cut/grind off the open end to get your two tabs.
<HR></BLOCKQUOTE>
Excellent idea Tony!
AndyR
Cincinnati
Referring to an old post, I believe Tony-Vipermad used a 15MM socket to make the tool. I used needle nosed pliers with success myself.
LPE 383
South Texas, USA
you can also put speed bleeders in, open them and that will allow the piston to push in without much pressure at all.
KERS-VPR
does the rear piston turn in clockwise or counter-clockwise?
GreatWhiteKAC
