Anyone know viper wiring?
SapphireGTS
Columbus Ohio
Does anyone know of a (headlight switched) wire in the cabin that I could tap into to power another light to so it would come on with the headlights? Say, for the light on an external gauge?
Thanks!
Keith
Vipermed 97.01
Tampa Fl. USA
On your dimmer switch look for a light green wire w/a white tracer,you can tap into that which will allow you to dim also
SapphireGTS
Columbus Ohio
Sweet! Thanks man. That helps alot.
I take it the dimmer switch is the little wheel that allows you to dim the dashboard lights? I am used to reffering to the dimming on a car stereo as the ability to dim the stereo automatically when the lights come on.
MaxedGTS
Ohio
That be it.
Max
SapphireGTS
Columbus Ohio
FYI - on 2001, the dimmer switch wire needed for external gauge light is the orange wire on the dimmer switch.
shibbydude
