Anyone need a new set of Gen 1 Front Factory Brake Pads?
0260in3
St. Louis, MO
I bought a couple of sets of Mopar (Brembo) brake pads off the internet. It turns out the seller thought both sets would fit an '02 but one set doesn't. I've decided to help the lady out who sold them by offering them here. The Part # is 04720986 and includes the pads, 2 pins, and 2 spring clips. I think these are normally a couple hundred bucks per set. I'll ship them anywhere in the continental U.S for $100.
Terry
99 R/T 10
Enterprise, AL USA
Brakes are all the same for 92-00. I believe the fronts are the same for all Gen I & Gen II's, but I think the rears are different for the Gen IIs with ABS.
0260in3
St. Louis, MO
I took the pads to a local dealer and had them run the Part #. It came back that these pads were the fronts for a '92-'96 Viper. Can someone with a '92-'96 report back on whether there is one pin or two pins that hold the front pads in place? I suppose it could be true that '92 - '00 fronts are all the same.
SNKEBIT
western wisc.
Probably made from a different compound, (hence, diff. part #) but same in shape. 2 pins hold them in caliper. The rear pads are different for the '01 and '02 because of different rear caliper.
joebrett
