Anyone use a Sparco Rev in their car ??
Stephen Yap
Bay Area, CA
If you did can you tell me if the shoulder supports clear the door panels. Based on my measurements, it should but it is very close and the bolt placements on the floor would probably be a factor.
If you have another competition seat that you use which clears the door panels, pls. let me know. Thanks.
Stephen Yap
Bay Area, CA
REDSLED, did you see if the shoulder supports cleared the door panels? The Evo and Evo2 are wider than the Rev. An installation that I saw of the Pro2000 which is narrower than the Evo had to have the supports cut to fit. I want to avoid that if I can. Thanks.
JoeB
Danville, CA, USA
If I'm not mistaken Bobby Archer had the EVO 2 at Viper Days and I was told the shoulder support had to be cut off to fit in the car. Don't quote me though. You might try emailing them Bobby Archer is very helpfull.
Joe B
NCVCA
Raleigh, NC USA
I have a pro2000 and another local racer has a evo2. Both of these installations use new mounting points due to roll cage and seating preference requirements - but they certainly fit inside the interior compartment - even with the cages.
VinhyVegas
