Anyone with Eibachs,18X11s on GTS?
dun4791
Peotone, Illinois
If you are running aftermarket 18X11s on the front lowered with Eibachs what size tires are you running? 275s seem to be too small for the rims, and through some searching 295s will rub the hood.........Experiences?
TexasPettey
Austin, Texas
My Gen1 is lowered quite a bit, perhaps as much as 3/4" up front. I run 305's or 295's up front on my track rims. I have had no problems with rubbing. When I run 315's, there is a bit of an issue in that the wheels must be straight to open the hood.
Russ M
LA, California
18x11's on front, gen 2 rt with eibach's same as gen 2 gts far as you are concerned. Your only issue on rubbing will be when you open the hood. Your hood will slightly touch the tire during opening and closing.
