APEX LETHAL 750 PACKAGE DETAILS AND PARTS
LTHL VPR
Thank you for your patience. I have finalized the list of parts we are offering in the LETHAL 750 package. As you will see, this is truly a PACKAGE (packed with parts!). It not only offers complete power upgrades, but also includes a number of additional parts in order to reach our goals for ultimate drivability, reliability, and longevity. We encourage you to compare the components of our package with other tuners. We think you will agree that the parts included in this package represent some of the greatest values offered to the Viper world! We are finalizing prices in the next couple days, and we will post them shortly.
Here we go.....
LETHAL 750 CONTENTS: 550 cubic inches and 9 liters
<UL TYPE=SQUARE>
<LI>Remove, inspect, and prep block for stroke and bore
<LI>Custom aircraft billet steel keyed stroker crankshaft
<LI>Billet steel connecting rods
<LI>Custom forged pistons
<LI>Heavy duty main bearings
<LI>ARP hardware, min. 190,000psi tensile strength
<LI>Balance and blueprint complete rotating assembly
<LI>APEX custom-grind hydraulic roller camshaft
<LI>Cloyes true roller timing chain
<LI>APEX exclusive high-volume fuel injectors
<LI>Extrude Honed intake manifold
<LI>APEX/CDI headers with ultra-high-temp (2000 degrees) ceramic coating
<LI>Mopar Performance cylinder heads
<LI>Full porting, polishing, and assembly of cylinder heads
<LI>Mopar "Race" spark plug wires with built-in heat shielding
<LI>Corsa 3" cat-back system
<LI>APEX 3" high flow catalytic converters
<LI>Precision-balanced harmonic damper
<LI>Unitrax Ultra lightweight (heavy duty) halfshafts
<LI>T&D 1.7 ratio shaft-mount rocker arms
<LI>Manley chromoly pushrods
<LI>Fluidyne radiator
<LI>180 deg. thermostat
<LI>Silicone radiator hoses with air bleeders
<LI>APEX carbon fiber air box with 3.5" outlets
<LI>70mm throttle bodies
<LI>Oversize smooth tubes
<LI>Lightweight aluminum flywheel
<LI>APEX Dual Kevlar clutch kit
<LI>Ripper shifter
<LI>All fluids, gaskets, bolts, etc.
<LI>Custom computer dyno-tuning
<LI>Labor
<LI>Before and after dyno with printouts
<LI>"Lethal 750" badging and serialized interior plaque
<LI>Detailed documentation and pictures of installation process
[/list]
OPTION 1: Interior Package
1) Custom 'color-matched' full leather seats with Viper logos & RT/10, GTS, or ACR logos, and center console with LETHAL 750 logo. Avalable in 2 patterns
2) LETHAL 750 pedal set: Available in either brushed(satin) or polished aluminum with rubber grippers for a non skid surface. Lethal 750 offered in choice of colors on the pedals (made exclusive by ZAF)
Option 2: Brake Package
1) StopTech 4-wheel brake kit offered with Pagid street or racing pads
L
LTHL VPR
Jim-
In short....no.
There is so much torque available EVERYWHERE (at least 700 ft/lbs from 2500-5500 rpms with peaks above 830 ft/lbs) that a gear will do nothing more than spin the tires all the time. I have 3.07s in mine and it just hooks up in 3rd gear. We can certainly do gears in your car, but unless you plan on using slicks, it will probably accelerate slower due to traction loss.
Hope this helps!
In either event, I would HIGHLY recommend you do the package without gears first, and then see if you still want them afterwards. I would hate to see you waste your money on something that you may not like.
Hope this helps!
-Wayne
L
LTHL VPR
Good News: We have finalized the pricing for the LETHAL 750 Package!!!
Given the enormous number of parts included in this package, our goals was to price it competitively with the other stoker packages, yet offer a MUCH better value (more parts for your money!!) We encourage you to compare the list of parts in our package to other tuners. In some cases, we have found that we are including over $8,000 more in parts and yet are priced below other packages!! This is the true value.
Here you go:
LETHAL 750: $36,999 Complete Package including installation (see first post for list of parts)
Option 1: Interior Package. $4995 (see first post for contents)
Option 2: Brake Package. $5895 including installation and Pagid Pads (see above(
SmokinV10
Houston, TX
Why is the brake package so much? It seems that you are charging over $1500 or so for the installation of the package? Even at $100 an hour thats 15 hours?!?!
SmokinV10, the StopTech 14" front/13" rear brake kit is $4,995 plus labor. That's the kit with the parking brake. They do sell a Race kit for $4,495 with no parking brake and no pads, which might be what you're thinking of.
potterb4
