Are the rear Koni Shocks adjustable on a 95 RT/10?
dblankenbaker
Scottsdale, AZ
Yes. Rebound is adjustable, but you have to remove the springs to do it. Compress the shock all the way until you feel the adjuster engage (you'll know it when you feel it). Twist clockwise all the way (about 2-3/4 turns) to set max rebound in the rear.
kverges
Dallas, TX USA
No ride height changes should be needed. Stock shocks have fixed spring perches.
BTW, you will rapidly tire of shock adjustments this way, as the remove shock, remove spring, and adjust cycle is pretty time-consuming and you will need a spring compressor.
Tim
Leduc Alta
Are there reasonably priced after market adjustable shocks available on the market for the Viper?
Tim
Tom F&L GoR
Wappingers Falls
Don't forget tire pressure. Tires are springs, so softer or stiffer with more or less air will change wheel hop characteristics also.
The rears are the like the 76, 80, ...8240 series.
Koni adjustment
Tom F&L GoR
Wappingers Falls
Check the two bolts on the differential housing that attach the torque bar. Mine were loose.... once. They require mega-torque to tighten.
