Autocross Alignment
Trailertrash
Huntington, Indiana
My second auto cross event is this weekend. Just put on a new set of Hoosier A6 tires and did a moderate track alignment.
Front
Camber -1.9
Caster 6.0
Toe out 1/32 per side
Rear
Camber -1.3
Toe IN 1/16 per side
Did some testing at a local parking lot and what a differance!! I have always had new street tires and ran them to death. And occasional used slicks. Never did a track alignment before either. Now that I have the slicks and the alignment its like a totaly differant car. Now its time for a real set of seat belts as my cornering G's just went way up.
The viper is one awsome machine. Hope to wip up on a few corvettes Sat and Sun.:headbang:
jay01m
Virginia
I'm not an alignment expert, but have been told that for auto-x you want as much caster as you can get. Not sure if that's true or not though.
T
Trailertrash
Huntington, Indiana
I took second place behind the winning time by 1.3 seconds but I was voted the top novice driver and won a SCCA membership for next year. I would like to improve on the current alignment settings I have more for autocross only not as a street car. I feel the car is handling very well but the A6's give up alot once hot. Any tricks to tighten the car up all the way around?
Omaha NE.
With a lot of static negative camber in the front you don't need a ton of caster, all that does is slow turn in grip and lessen braking effectiveness. You are OK with 1.5-1.9 in front with 4.5 - 6 degrees of caster. The rear I would put more rubber flat on the ground by reducing the camber to .7 - .9 max negative. The rear toe should be fine where you have it. The front if it is darty actually makes the Viper harder to drive because you feel as though you are chasing the rear all the time. You may be better off dialing that back to 0 so the car is better under fast braking and turn in at an autocross.
escapedan
San Jose, Ca
Good points Mark (thanks again for the call regarding the brakes the other day - sorry we missed each other.
I use 2 degrees negative camber in front and rear with some pretty aggressive toe out up front and slight toe in in the rear (also on A6s). The turn-in for autocross is outstanding and I am able to keep the rubber on the ground without wheelspin. I have ~40 runs (not days) on the A6's and will be rotating them after the next event.
That setup on the track is down right sketchy. At much higher speeds the toe out makes it very darty. Good luck, I'm always happy to hear about another autocrossing Viper!
escapedan
San Jose, Ca
Oh, if you are ok going into ASP (vs. SS) get yourself a good set of shocks - I suggest Moton. You think the car handles good now....you ain't felt nothin' yet.
T
Trailertrash
Huntington, Indiana
Thanks for all the positive feed back. In autocross our speeds are low, the car is very stable until until the 4th time out where the slicks are to hot and I start to push through the corner. The rear grip seems fine unless I over power the turn out. I'll try -2 camber up front and leave the rear alone. I have been running 33psi all the way around and I no I need a pyrometer to check tire temps I'll get there. Tread wear is even for now. Should I spray the tires down with water between rounds?
1TONY1
Dalton Ga. (Chatt. Tn.)
Your tire pressure is too high.
Start at 26 and go down from there. I know what everyone at the autocross will tell you but I don't care what the norm is for the little tire guys...they can run their 45 and 50 psi all day long. :D
Madduc
Fremont,MI
Thread jack...hey Tony, what would you recommend for rear tire pressure using BFG R1's on my ROE'd (695rwhp) aggressive street driving??
GreatWhiteKAC
