BAD BOYZZ GARAGE
BAD BOYZZ GARAGE'S GEN 3 High Performance Viper Engine Package. Run with the GEN 4 ACR's with out doubt all on 91 Octane Pump Gas.
This is the Engine Project that started Chrysler's New ACRX Header Program. On our Winston West, Sprint, Cup & Gold Series Engines we always run long tube burns style merge collectors to achieve maximum trq & hp levels, so this is why I decided to go with the tubular 5 into 1 merge. This Burns Style upgrade makes more trq & hp throughout the entire rpm range over the Tri-y's and responds better to High Performance Engine Modifications.
Thanks to all for showing interest. Our BBG 650 really recieved alot of attention at the VOI 11.
"Stay Tuned" as we are finishing up our BAD BOYZZ SERIES - GEN 4 Viper Race Cylinder Heads, GEN 4 Race Lower Intakes & GEN 4 Lightweight Flywheel/Clutch Assemblies. We debuted our prototypes at the VOI 11 and really appreciated the great response! Rest assured that the same extensive developement is being done to BBG's GEN 4 package (Race Prepped Viper Heads, Raced Prepped Lower Intake, BBG Viper Twin Lightweight Flywheel Clutch Assemblies, MGW Shifters, ACRX Headers with High Flow Cats, OS Giken Race Diffs with 3.33 or 3.54 Gear Ratios) all on 91 Octane!
Below are some specs for your review:
=BBG 650= Unleash your GEN 3's power!
BBG 650 - GEN 3 Viper Raced Prepped Cylinders Heads:
Fully Ported Intake Runners
Fully Ported Exhaust Runners
Combustion Chambers & Bowls Re-Worked
New Ductile Iron Valve Seats
New Bronze Valve Guides
Sprint Series Stainless Steel Race Flow Big Valves (BBG custom spec)
Sprint Series PSI Dual Lightweight Race Springs (Polished & Chamfered)
Sprint Series E300 Steel Lightweight Race Retainers
Sprint Series Super 7 Radius Top Lock Hardened Machined Keepers
Sprint Series CV Machined Stands
Sprint Series Viton Seals
Deck Milled
Intake Face Milled
Approxiamte Compression Ration 10.5 to 10.7
BBG 650 - GEN 3 Viper Race Prepped Intake Manifold:
Port Matched Runners
BBG Air Diverter Machined & Installed
BBG 650 - GEN 3 Viper Roller Camshaft:
Roller Billet Copper Core (BBG custom spec approx .626 Lift)
BBG 650 - GEN 3 Viper One Piece Hardened Pushrods:
Trend High Performance Products
105 Wall Thickness
220 Degree Top Radius
BBG 650 - GEN 3 Gasket Kit:
ACRX Head Gaskets
Intake Manifold Gaskets
BBG 650 - Custom Calibration SCT Tune (DC PERFORMANCE):
Recommended Options:
BBG 650 - American Racing Headers:
1 3/4" Straight Through, Long Tube Merge Style Collector
Turnouts with High Flow Metal Cats
BBG 650 - Crower Competition Shaft Mounted Roller Rockers:
1.7 Ratio
Needle Bearing Roller Tipped
Viper 5 Cylinder Stands (one piece)
BBG 650 - GEN 3 Billet Valve Cover Spacers:
Below is Attached PDF with BBG 650 Viper Cylinder Head Flow Numbers (Please note that these numbers are conservative becuase they are based on flow rates utilizing our stock intake runner machined flow bench plate). We believe in being conservative on our flow numbers and our power delivery levels so that you will be pleasantly surprised with your build. Here are a few behind the scene photos of the developement of the BBG 650 Head, Intake & Cam Program.
Please feel free to contact me personally with any techincal questions before, during & after your build.
Thanks for your consideration,
Toddy
Deck Milled
Intake Face Milled
105 Wall Thickness
ACRX Head Gaskets
1.7 Ratio
Toddy
