Best way to keep GEN 2 rims clean and shiny?
spikeone
Quebec, Canada
What is the best product you have used to keep your Gen 2 rims shiny?
Considering they have clear on them, I doubt using a metal polish would make a difference?
VIPER GTSR 91
Spring, Texas
NO metal polish since they are cleared. Just use soap and water, hose off, or a good wheel cleaner or detail spray. Then a wheel wax to shine.
spikeone
Quebec, Canada
that's what I been doing and they get dirty really fast
might be time to swap out my brake pads (no idea what they are) for some low dust ones since they seem to be the culprit in all this
mad0953
Southern Oregon
This may sound a little too anal for most but I use a Swifter duster on my wheels after every drive. Works really well and wheels look great.
VIPER GTSR 91
Spring, Texas
Yes, that is from the OEM pads especially in the fronts. They are really messy. Search here for the many pad threads and you will get good info on low dust pads like the EBC green etc.
Bird325
Ft Worth, Tx
I went to ceramics on the front and EBC reds on the back. The dust problem is almost totally non-existant. A word of warning though, this setup needs to warm up when you first take off before it has maximum stopping power.
sshorty
Independence, KY
Be careful using Simple Green and/or Swiffer Duster. Your best bet aside from using the low-dust pads (assuming you're not participating in track days), is to properly clean and seal the wheels. I recommend using a good wheel cleaner such a Bilt-Hamber Auto Wheel or a Sonex, followed by a Bilt-Hamber Korrosol or Iron-X to remove any remaining metallic particles that are still in the wheel, then clay using any one of the soft/medium clay bars with the corresponding lubricant. Once complete I would dry the wheel and check for any remaining debris. Apply a good wax and/or sealant such as Collinite Insulator Wax and/or Menzerna Power Lock which will make the wheel finish look better than new, but also protect better than most other options. After a long drive, you should be able to hose off most brake dust followed by a soapy wash to get the remainder off. Good luck and let us know what method you try.
denniskgb
Sewell, NJ
I use Windex on factory wheels myself. Spray a ton of it and wipe down with paper towels.
agentf1
Phila Suburbs
NO and NO... Windex will strip any protectant or wax you have on the wheels and paper towels are very abrasive and will scratch the clear coat on them.
I wipe them down with a microfiber wet with a QEW solution after every drive, then dry them with another microfiber. I also routinely coat them with Zaino Z2p so that the brake dust does not stick blows off easily.
DrTaco
Oak Lawn, Illinois
I use WheelWax at the beginning of every season and then a california forked wheel duster (blue) after or before each drive. Hardly have to touch wheels during my 2-3 washes per year. I also have different pads and keep the car in a Carcoon, so that makes a huge diff I'm sure.
Drock187
