Boosted guys - Vacuum lines on front of intake. Cap them off?
-FROG-
Austin, Texas
I started my car today with my Paxton. When I tap the gas, it goes deeper into vacuum, instead of boost and my fuel gauge goes down, instead of up (It's set at 50psi with the vaccum hose plugged in). I have my blow off valve plugged into one of the vacuum ports and the tiny port located on the top drivers side of the intake is where I plugged my boost gauge in.
So the vacuum ports I am talking about are the 4 symetrical ports on in the front of the intake above the thermostat. I originally capped off the ones I wasn't using but my car isn't running right. Sputtering and sounds off.. My experience tells me it is those vacuum lines causing it so I need to figurre out how to plug them or how to rout them.
The 4 vacuum ports originally went to the emissions charcoal canister. I removed all that crap.
Thanks!
F
-FROG-
Austin, Texas
I think I got it all taken care of. Car started up great and sounded NASTY this morning. :)
rlamorte
