Brake Fluid
2snakes4us
Nixa , MO
I know the Service Manual states to use only Mopar brake fluid for my 94 viper, but can I use Valvoline Full Syn Brake fluid with out any damage to the brake system? It says it exceeds dot 3and 4 fluid.
thanks guys.
Janni
Raleigh, NC, USA
You are fine. to realize the true benefit - you'll probably have to bleed through about a quart to get all the old stuff out - but folks are using fluids from Ford High Performance to Castrol SRF.
Luke@tirerack
agreed ... take a look at ATE super blue (unless you live in Florida) it's a very good product with a high boiling point
Viper X
I've had reasonably good luck with Motul RBF 600 brake fluid.
SKY1960
