Buying a short shifter...
J P Jones
Chicago, IL
I'm a newbie to Vipers with my SRT. Where's the best and cheapest place to purchase a short shifter for the SRT? Thanks in advance.
CaboViper
Ben Lomond, CA
I installed the MGW short shifter. It inproves shifting and also looks great. Installing was a hassle because factory shifter is on extremely tight. Make sure you take off the ring assemble around shifter or you could tear it up.
Frank 03SRT
Somewhere in Kansas
Yes, the shifter is on very tight, but it is extremely easy to remove the nut. Take two wrenches and place one on the shaft and one on the nut. With the other ends about 1-3 inches apart (considering the lefty loosy rule), clamp one hand down on both at the same time. It's a snap.
By the way, when the directions say don't tighten the rings screws too much, there was a reason. One of the nuts on mine was already stripped, and I had to fiddle with it to get it to hold. That was a pain because to get to the nut, I had to take off the ring and all other 5 nuts twice!
FASTRNU
Dunwoody, GA
I installed a B & M Ripper shifter on my Vette and it is really nice. Haven't missed a shift in almost 2 years.
Dave
